different scanners same systens
I am using software specific to each scanner. And I worked out my simulcast issue with a corner reflector. It's just two different scanners, a Pro-668 and a PSR-500 with the same systems programmed in and the same everything, talkgroups, etc and one will pick up the system and the other will not. And two other systems both scanners will not hear them. On one the talkgroups shows up on the monitoring software but no audio. Does sound like a simulcast issue but the system is not simulcasted.
