16cessna34
Hi Lately my scanner has not picked up some police activity in the area. Do I have to periodically update the Radio Reference Database? How do I do that? Thanks
The above works if you are using the full database to listen to. If you use favorites lists you will need to update those.Since you included BCD436HP in the thread title, I presume you're using the Sentinel software that came with the scanner.
Open Sentinel, at the drop down menu item Update, use Update Master HPDB. Let the software work, then when finished, write to your scanner from the Scanner drop down.
WS1095/536/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
The best solution is to update the full database regularly so when you are in the field, you have the latest if you go to the database.Ah, thank you for that info, both of you. I don't suppose most of the frequencies I track are going to change much without me hearing about it somehow, but I only have a few FL's. I don't envy those who have numerous ones, though.
Naturally I have changed those names.If you simple use the APPEND function from the master dB, it will update your FL with any new channels PROVIDED that you didn't change the System/Department names.
Highlight the part of the Main Database that you would like to append to your FL and Right click on that. This should give you a menu of possible actions and the very top one "append to favorite's list" is the one you want. When you click on that it should then ask you which "favorites list you wish to append to".
