I have sites assigned to Quick Keys 1-12. I am able to use Quick Keys 1-9 but when I try for 10-12 I cant enter a 2 digit Quick Key.....any ideas as to why??
Quick key 6 (for example) is just a short code for .06
Press .0 to bring up the "S0:1234567890 line to show you which Quick Keys in the range 00 to 09 are on/off.
A little tip for making it easier to operate your scanner when using Quick Keys.
Include the quick key number in the alpha tags for your systems/sites and groups. Then you can tell with a glance at the display which QKs to disable/enable.
You can also go to Menu>Program Systems and scroll down through your systems to see which QK is assigned to which system/site.
This really helps when you have over 100 systems as I do.
