I programed a Walkie-Talkie channel just to see if it works... And it does, But now i cannot figure out how to delete said channel. Is there anyway i can delete it without resetting the whole scanner? Thanks in advanced.
Trying to remember. Did you try programming 0.00 as the frequency? Some of the old RS radios would actually zero the channel as opposed to telling you the frequency is out of range.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
I am sure there is some non obvious way to do it. Try downloading the manual. Unless another old RS radio user sees your post, it might be a while to get an answer.
Until you find something interesting to replace it with. With only 20 channel entries it shouldn't be hard. They are decent old scanners (yeah I got one) within their limitations, just a bit of a slow scan rate and crappy pots being the weak points.
