BFDX BF-TD501 uhf for DMR police scanning?
Will it work?
I setup a LUITON DG-TD501 UHF for a coworker which by all accounts is the same as the BFDX BF-TD501.
The programming software and drivers were easy to locate and install and the software is decent to work with. The software copies the Hytera radio programming structure. No English language tutorials or programming support are available, that I could find at least. Got it working and serving it's purpose. Mind you, it's just setup to monitor one business.
If you go with this unit, you will still need to utilize DMR Decode or DSD to secure the needed color code, repeater slot and call id's.
Bad news? This unit will probably never receive a firmware upgrade which is very important for a DMR radio and support is nonexistence. No copy-paste or import function either. Only 160 presets are available over 10 zones.
My advise, take a good look at the CS750 from Connect Systems. It would be my go to if I needed a DMR radio.
With a CS750 you get a unit that has had repeated firmware upgrades since release, English based support via phone/message board/email and if what I read is correct, no need to utilize DMR Decode or DSD to secure the required information to monitor a system.
