Before I pull the trigger on the BCD536HP I have been reading as much as i can. I noticed that the BCD536HP has display issues. If i run this radio at a lower brightness then max will the display still fade out over time? I really don't want to drop $500 and have problems down the road. Thanks for any and all help/advice
Mike
Hi Mike---- I bought a 536 about a month ago and could not be happier--- great scanner. And I have been running the brightness at the lowest level whenever possible to try to avoid issues down the road. Of course, sometimes when I am in the car with the radio in bright sunlight, I sometimes have to crank up the display brightness, but I try to avoid it whenever possible.
I just that Uniden acknowledges the problem and comes up with a better solution than just running it at a lower level.
Enjoy your new 536. Somewhat of a learning curve, but patience will pay off.
