Source Label is the alias/name that you assign a User (Radio ID). If you haven't manually attached a label to it, it will default as an empty field. The same would happen in the Target Label field if an unknown/unidentified Talkgroup showed up or if you didn't import the system from RadioReference. It would default to nothing until you identified it and labelled it yourself.
