I bought an MFJ 941E tuner and the transmitted and reflected power gauges don't seem to be working, at least in my setup. I'm feeding 450 Ohm Window line from the balanced output. I sent it home with a coworker and he plugged it into a dummy load. It seemed to work just fine there. I've put up to 100 watts through this thing (on the appropriate setting, 30 watts on the low power setting) and the needles don't budge. But, it worked fine for my coworker. I'm thinking it must be the impedance of the ladder line. The internal Balun is a 4:1 and I suppose I should really have a 9:1. I was expecting the gauges to still move a bit... but, it's not a good match.
All this said, I was able to tune for signal strength on receive and make contact with a ham in Ontario (from Ohio). My first HF QSO! I think I must have been marginal.
So, if I get or make a 9:1 balun, will this likely solve my troubles? Or do you think there's something else wrong here?
