2014 Chev Equinox
Res21cue
Res21cue
Anyone able to give insight into some install options for a 2014 Equinox? Any pics?
The Little cubby hole behind the shifter is not wide enough to hold anything.
Thoughts?
I did one a few months ago, might have been a 2015....
Getting power from the battery through the firewall was hard, but we found an existing grommet that we were able to make a small incision in to sneak it through. Found a ground under the dash to use. Coax was routed underneath the seat to the door trim and then back to the rear C pillar and to the antenna.
I do believe we mounted the radio behind the shifter, but it was a small control head. Wish I'd taken some photos.
