I have been playing around with my trusty old GRE SuperAmp (the portable version) and decided it was time to use it more often at home for some specialized applications.
According to the manual it uses 9VDC with the tip negative for the external power supply. I am surprised at this since most everything else uses tip positive.
Amazingly I have no 9VDC wall warts in my junque boxes at this time (I must have done a good job of weeding things out when I moved this spring...) so it is off to Fry's this weekend.
My questions are:
1) Is the manual correct, is it really tip negative?
2) Has anyone had any heat build up leaving it connected to external power for extended periods?
My questions are:
