Nitebeat
I am in a similar predicament and did not want to start a "new" thread. I live in Staten Island, New York and want to be able to monitor the NYPD, NYFD, EMS and perhaps some of the nearby agencies such as PAPD, TBTA, etc. I currently have the ancient Uniden Bearcat BC248CLT which is limited in functionality, including the inability to enter frequencies with 5 places to the right of the decimal point, amongst other limitations. Can someone advise which manufacturer, model scanner I should consider, that does not require a degree in engineering to program / maintain or should I be looking outside of the "scanner" world into something more professional? I need the ability to monitor multiple frequencies i.e. "scan" and the only option I have as far as placement is the desktop with antenna attached to the top / rear of the scanner / radio. I do not have the ability to use an external i.e. roof or other type of antenna. Any and all suggestions, assistance, etc. will be GREATLY appreciated. Also, I believe if I am to go the "scanner" route that 'ScannerMaster" is the place to go to for purchasing or is there another place(s) to shop at?? Thank you to all!!!
