cartwright
Two NooElec T2.5ppm sticks running Unitrunker Rel 32 on Win 7 Pro 64 bit six core AMD processor 3.30Ghz and 12 GB of RAM.
Motorola Smartnet II Analog system simulcast four sites. I am closest to site 4 which I receive great almost full quieting. Problem is two fold.
1) Multiple agencies tie into Ambassador CEB through various carrier facilities. Home agency (Fire / Ambulance) where Ambassador is located has console ID's for each position module. Receive their audio from mobile and consoles 5 by 5. Trouble is when remote agencies transmit, I receive all mobiles fine regardless of patch, MS, or other call set up, however dispatcher RID shows up for all agencies as 65535 and other "common" ID's shared by them. Their (dispatcher audio is clipped or muted a lot depending on RID used at the time as it rotates even though its the same dispatcher) Only happens on remote agencies coming in to the Ambassador from remote. Never for the home located agency. I also notice a TG comes up and goes back and forth between channels for the site despite the matrix priorities given higher values.
The last issue is with the bandplan. It was populated by the system, and showing up rebanded but is in the 851-853 old spectrum. the first slot has channel 0 thru 453 and the second line shows a jump to 866 Mhz and higher on each successive line. Since this system was converted from a three independent site Motorola Smartnet I and II Hybrid which are supposedly running for local telemetry and SCADA, could there be either pollution in their database or just programming issues? I notice TGs in Unitrunker that are Locked and 99 priority will air the audio occasionally despite everything set differently against the logic.
Health is 100% CC on one dongle, Voice on the other. Audio is great as with operation except these quirks above.
Sorry for the length, but I have been trying a lot of different stuff attempting to isolate the issue.
Much thanks
Oh and all the agencies are Countywide. No site specific operation.
Much thanks
