Part number needed Motorola R1225 Accessory Connector
devnu11
I need to purchase an accessory connector for a Motorola R1225 repeater. The 16 pin CM200 connector does not seem to fit. Does anyone know the motorola part number for the rear of radio 16 pin connector?
Thank you
devnu11
as a side note the connector I have fits properly in the GM300 as well as a CM200. The R1225 I have does not have a locking mechanism on the bottom of the connector on the rear of the radio.
devnu11
"Same connector......" It sure looks like it but this one just won't fit. When the service manual arrives I will be able to look it up. In the mean time I guess I could get out a knife and cut the lip off the plug I have. I just envision an ER visit from trying to do so...
cmdrwill
So Cali
"Same connector......" In the mean time I guess I could get out a knife and cut the lip off the plug I have. I just envision an ER visit from trying to do so...
BAD Idea.
As others on your multiple posts have offered: Carefully check the pin alignment in the radio.
You may have a knock off plug.
