Thank you for that information.
I don't actually care about the audio at all. I just want the ID number of the currently rx'ing unit. I know it all comes together though.
One of the main reason for using SDR was to get the ID number of the rx so we can see exactly who is currently sending on the radios out in the field at any time.
I want to get that ID number into a computer somehow (it doesn't matter how, just some interface to get the ID text into a computer).
I have found no way to interface with the mobile radio (APX I believe) without using an extremely expensive Motorola dispatch type of console, $15K+.
That is extreme overkill for just getting text ID numbers into a computer, as we don't need all the other capability of a console.
So, my initial thought was to use SDR to get that ID data into a computer and bypass the APX altogether.
If that isn't a viable solution, do you know a cheap way to interface to an APX or XTS/XTL or anything that would get the ID numbers into a computer?
I don't care if it is serial or USB or RS422 or whatever. Once there is a method to get the currently rx'ing ID number into a computer, I don't care about the audio.
Ah, OK. In that case this is much simpler.
First of all, this is a conventional (non-trunking) Phase I system, right? If not, things are a bit different, but let's deal with the conventional option first.
P25 unit IDs aren't encrypted, even when encryption is used. So you don't have to worry about keys, even if the system is encrypted. (Yes, this means that outsiders can do traffic analysis, too, but that's how the P25 standard works).
A cheap SDR with a laptop or PC running Gnuradio and the Open P25 (OP25) package is likely to be entirely sufficient here, if you don't care about voice decoding. You can get the software here:
OP25
Note that this is not quite "plug and play" production-grade software. It will require some hacking to make it work. But if you want a cheap, quick-and-dirty over-the-air logging system for conventional P25, it may be just the ticket.
Another option, which I use in production, is an ICOM R2500 software controlled receiver with some software to capture IDs. I actually use this (with our own software, not ready for prime time) for my P25 capture setup for logging clear vs encrypted traffic. The ICOM is a better receiver than a cheap SDR. With the default ICOM software, just put the radio in monitor mode on your channel and enable ID logging, (You can't scan multiple channels this way, so you'll need one radio and laptop per conventional channel).
If this is a trunking system, other options apply.
