Hi i just bought a motorola cdm1250 and when i key up it restarts if i take the antenna cox off the back its keys up just fine
what should i do
could it be the antenna
No antenna forces it into low power mode. And, removing the antenna and transmitting is a good way to kill the finals.
Anyway, it sounds like inadequate power supply, especially if you are doing this on the bench. When you force it to low power mode, it draws less current.
FWIW, that has been a common question over the years here on RR. Had you searched, you'd probably have found that.
Search tags: The Professional or Waris
Series of radios includes:
HT750 HT1250 HT1550
EX500 EX600 EX560 EX650 PR860
CDM750 CDM1250 CDM1550
HT1250LS+ CDM1550LS+ CDM1550LS
It may be helpful to search using wildcards.
If someone asks a question about one model,
the answer usually pertains to most, if not all.
They are all programmed with HVN9025 CPS.
