Dear Paul
Thank you for the answer
I have made some tests and it looks like the problem is not the Noise radiated from the computer as i have mentioned that the noise is only start when i press the Play button (start) of the SDRSHARP
so i suspect that the noise is coming from the USB cable and entering directly to the antenna
since i Have replaced few cables and tried ferrite too and not much results i suspect that the noise travel (or even generated ) from the data line (after all 480MHZ 5V Square wave produce harmonics and noise that can exceed micro volts easily) and even with good EMI Filter in the receiver it pass to the antenna input
if thats the case i dont think that a farady cage is the solution because the noise that present inside the receiver on the USB data line is already there however i can make test and put the receiver inside metal box and see how the noise floor is
I know that some things done by few persons that reduced the noise
one of them is scrapping the paint and making the box more Electrical conductive and by that not allowing signals to enter the receiver not via the antenna
I also read that someone else put copper RFI tape on the USB connector shield inside the receiver and attached it to the ground and that also reduced the noise im looking for the actual ways that really solved the problem by peoples who did it and succeed and thats why i have asked it here to get the experience of the peoples that could eliminate (or reduce) the noise
As for SDR with Computer i have no experience with say FlexRadio or RFspace SDR but it looks to me that if there was a problem with them i would hear it already and i didnt hear peoples say that the receiver pick up noise
so i think that SDR can work with computer and give sensitive reception with internal antenna
honestly im quiet disappointed from the results with internal antenna the 10 MHZ wide was a big advantage but if i cant use it in the field then a regular receiver can do the job for me much better
and the receiver behave with external antenna is far from being good it tend to overload very quick
So i hope someone read it and could use the receiver with the setup i have and succeed to get reasonable results
73's
Ronen - 4Z4ZQ
Ronen Pinchooks (4Z4ZQ) WebSite
