Chamimnya
Hello all,
I've been looking to improve the reception for my BCT15X scanner that I've been using to monitor RCMP in Burnaby. I've never used any antenna other than the stock one but I have decided that I should finally take the leap since I intend on hosting a feed in the future.
I'm looking for something that I can use indoors and my budget is under/around $40 (I'll go over if required). Also if you could include any other information I may need, such as cables, connectors, or mounts, I would appreciate it. I do believe the BCT15X uses a BNC connector.
I heard that the RS 800Mhz antenna is a good bang for the buck:
Radioshack - Products
Or maybe even one from here? http://www.theantennafarm.com/catal...ular-range-198/high-gain-800mhz-antennas-223/
On a side note, I also have a BC345XT that I use for monitoring the EDACS control channel, I'm not sure about whether I should stick with the stock rubber antenna or go with something better.
I would like to hear about anyone else's setups and antenna recommendations with the E-Comm (WARS) system. I'm monitoring ProVoice so if anyone has any tips in that regard, feel free to share, I have not been getting a very good decode rate through DSD (60-80%) and I'm assuming that's because of the not so good reception.
