Is Fleetsync ANI encrypted along with audio?
radiointhesky
Using conventional Kenwood analog radios with scrambler chips, is the Fleetsync ANI encrypted/scrambled along with the voice? Or is ONLY the voice encrypted?
RayAir
Just the voice.
Is this built in inversion scrambling?
radiointhesky
Yes, I'm pretty sure it is.
Which SDR program will show the ANI? Unitrunker shows trunked moto P25, but it doesn't show anything for the Kenwood conventional fleetsync.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
IIRC there is an app for Android and iOS devices that decodes FleetSync but no native desktop program. The app actually works on speaker audio - I have held my phone up to my scanner and/or TK2180 and it has decoded the ANI very nicely.
It's called Radio ID by Matthew Kaufman.
DSheirer
Fulton, NY
sdrtrunk will also decode fleetsync ANI and GPS and can (un)invert talkgroups using simple frequency inversion.
Denny
radiointhesky
Denny
I had tried sdrtrunk already without success, but I probably didn't have all the settings correct, and I thought that maybe the scrambler prevented the ANI from being decoded. I will try it again since you say it should work.
Also, I don't know if it is FleetSync or FleetSync II. Would that matter? Can sdrtrunk decode I and II ?
radiointhesky
I have SDRTrunk working now. It shows the ANI numbers, and it keeps a list in the Events window.
However, I want it to write those Events to a file. I have all the checkmarks in the "Event Log" tab of the configuration, but the actual files are empty. They are 0KB files.
I have saved, exited, restarted, and even recreated the site and channel with new names ... and it creates new log files with those new names, but the files are empty, 0KB.
The application logs are working, but the event logs are not.
DSheirer
Fulton, NY
In the current build, events are saved to the log as they age-off from the window (500 events). This was to allow call event down times to be updated and the event recorded only once in the log.
I fixed this issue in the master branch on github ... events are saved as they occur and saved again if/when they're updated. The fix will be in the next release.
Denny
radiointhesky
Denny
I downloaded the master branch and compiled it this morning, and I still don't see any log files being written ... unless you meant that you changed it just this evening.
DSheirer
Fulton, NY
Pull the latest from the master branch. I updated the event log writer to flush the buffer after writing each event so that it's logged immediately.
radiointhesky
Ok I just downloaded the master and compiled. Yes, it is writing immediately. Thank you for that quick resolution.
