0.1 Amps is what he said.
Ya Tom, I threw in the "95%" because there can be other problems.
If the input circuit it damaged, turn the power off, open it up, and use your nose and ears, looking for burned things. An ohm-meter will tell you about open coils. Make sure you are not measuring something in parallel with a coil that will show continuity.
I just dug up an SB220 schematic. Have you tried more than one band, and does it act "sick" on all bands? L1, 2, 3, 4, 5 being open would cause a problem but it would be band specific. You can check the continuity of any of those inductors as long as the band switch is selecting a different band.
Burned RF relay contacts could also cause such a problem. That would show up on all bands and I would think it would put on a bit of a light show and you would hear it too.
Less likely but also possible would be one of the capacitors in the network shorting out. If someone drove it hard on the wrong band, there could have been some pretty abnormal voltages in the input network that could have poped a cap as well as an inductor.
I am sure there are a few less likely problems, but I would guess that damage in the input network might be found if you use your eyes and your nose.
Like W3DMV said, there is a lot of volts with a lot of current capability behind it in the box. Use extreme caution. Dont be afraid to be scared of it, because you should be scared of it. Done assume that if it is off that it cant hurt you. After you turn it off, give it a good minute to bleed voltage off and then still short out the power supply capacitor string with a screwdriver... just to make absolutley sure that it is indeed discharged. An open bleeder resistor could leave the capacitors in a lethal state for a long time.
Rick
