On the Txwarn P25 tower for Chamber county and others there not assigned FCC call Letters. So Who are in charge of the Towers?
I suspect that whoever created the site in the database did not have the information at that time, and it was never corrected.On the Txwarn P25 tower for Chamber county and others there not assigned FCC call Letters. So Who are in charge of the Towers?
It's kind of a balancing act. An "excellent" submission contains all parts and pieces needed to add the site to the DB. If the call sign is available then it should be submitted with the rest of the site info. However, all info is not always known or available at submit time - and we want the new site in the DB as quickly as possible then we go with what we have. If the Admin has extra time and a low workload then we can look it up. When things are busy and/or submissions are stacked up then we don't have the time to research all the individual elements. On the other hand if a user sees a missing callsign, the user can look it up and submit a callsign update; that helps us out quite a bit.
Thanks,
Russell
I have a related question here. I use UniTrunker to monitor sites with and I am pretty sure that on a
simulcast "site" (multiple towers) I have seen the call letters change from time to time if I monitor
long enough. Does this seem reasonable / logical? I always figured it was because the scanner
at that moment had locked onto a different site since all the control channels are the same.
Could different towers in a simulcast system have different call signs?
Martin KF5OPQ
