paininthetrunk
- Joined
- Jul 26, 2009
- Messages
- 41
158.835 no longer works.
Does anyone know if they changed PD to a trunk, or went digital?
Next thing I always do ( if you want to pursue this) is check the FCC license database to see if they have a new license issued for a different frequency or such. If that turns up negative, run DSD on their conventional VHF channel to see if their is DMR emissions and color codes that pop up. If so, that will give you the answer that they switched to DMR with or without encryption. If they switched to P25 in a scanner it should pop up the NAC code as long as you have a modern scanner and its setup to do wild cards and not lock onto a certain PL tone code that their using.
Simple way though is run DSD from a tapped scanner to check that. Also monitor the NJICS talkgroup and forum pertaining to it to make sure people didn't get hits from a new talkgroup that's theirs.
Woah way too technical for me John. Lol
The one thing I do know is that the FCC license for 158.835 was renewed in 2011 and good through 2020.
Yeah, Roselle Park is working just fine on 158.835. Keep in mind there have been times they switch to their secondary frequency as their main dispatch whenever they have a problem with their repeater. I would not be surprised if RP switches to NJICS in the future, since they have been seeking a new system for quite some time, but got rejected (for good reason) by the FCC in the past.
The town is 2 square miles, that's why. They don't need a mega Trunked System. The FCC rejected their previous Trunked requests because the town is too small, therefore not needed.
If there was a rejection, it more than likely happened during frequency coordination. A system has to have what's called channel loading (the FCC will return a license application for that, on certain frequencies, but the coordinators or regional planning committees usually catch it first). That is, a certain number of mobile radios need to be on the system. In some frequency bands, or to satisfy some regional plans, an applicant cannot ask for 5 channels and then go on to use them with 15 mobiles and 15 portables - or an applicant cannot ask for for a 25 mile radius area of operation when the entire community is 1 square mile (unless there is some other mitigating rationale, like they are the dispatch center for a mutual aid). Then again, there are some buildings that have their own trunked system inside. Casinos, manufacturing plants, and hospitals can have their own trunked systems if they have a lot of radios and a need for a large number of internal departments to communicate.
Many of Roselle Park's neighbors are going on to the NJICS system, and, I believe Union County has augmented the system's coverage by adding sites. A few municipalities to the west have also looked into the system instead of building out with their own resources, especially if they have channels on T-Band (470 - 512), as there's a lot of politics involved right now and those channels may be auctioned off.
Why would going to NJICS be appealing? The biggest reason is that even though a trunked system is fancy and can have fancy features, another agency (NJ) owns the infrastructure and pays for all of the updates and maintenance. The municipality buys "subscriber equipment" (mobiles and portables), they get programmed, and that's it. Something goes down? It's the state's problem. Need new firmware for system updates? It's the state's problem. Something goes wrong? It's the state's problem. Municipal expenses are actually reduced over time, even though the radios would cost more in the initial outlay. The only thing the town has to pay for is their own radios and can budget some for an accelerated lifecycle.
The other reason is that, over a period of time, the scales tip in favor of agencies that don't switch becoming the "odd men out" when it comes to operating at a common incident. The VHF frequency could take them so far out of town, but the trunked system has talkgroups that could be used while roaming. Not that I think giving up VHF is a good idea - like any network dependent technology, having and keeping a backup is important in case a point of failure affects your community.
