Thanks. I haven't heard anyone say that they are hearing much there at present, so maybe they are doing something with the system as was mentioned above. However they are already 700 mhz so aren't they already set? Could they still face rebanding?
I see the ADOT MVD enforcement talk group come up a lot...the bars are solid full scale as if the control channel is solid...the talk frequency flickers on and off on the display...never any audio. That's all I get....doesn't matter how close I am to white tanks or north mountain, been near both several times in the last few days but the same thing happens.
I also get the same exact thing with simulcast g, but haven't gotten close to a simulcast g site yet to see what happens on that system. That one is always difficult to pick up where I live. It would make me think that simulcast might be a real issue on this scanner, but simulcast a does pretty well, at least on par with my other scanners. Mystery...
1) My understanding was that the YRCS frequencies in Yuma (city) are being (have been) switched from 800 MHz to 700 MHz. There's no need to switch anywhere else as I believe (without looking at the DB) all the other sites were already 700 MHz.
2) The ADOT Enforcement and Compliance Division used to be a part of the Motor Vehicles Division as MVD Enforcement. Several years ago however, they were taken out from under MVD and made their own division under ADOT. I just want to try to prevent any confusion there
3) It appears to me that the White Tanks site antenna is aimed to provide best coverage to the far west and southwest areas of the county: Buckeye, Tonopah, Harquahala Valley, Gila Bend, etc. I live in Peoria, and reception from the White Tanks site isn't as strong as North Mtn, South Mtn or Thompson Peak. If you live in the Central Valley, try using those 3 sites. (South Mtn and Thompson Peak seem to carry everything full time, North Mtn may not always carry everything.) I have all 3 sites, plus White Tanks, plus Towers Mtn, in my PSR-500 with "Check All CC's".
I had no issues late last night listening to ALERT respond to an incident at Catcus Rd and I-17.
4) You may be close enough to one particular Simulcast A transmitter, that you're not receiving any others, so there's no multipath issues there, but you're receiving two or more Simulcast G transmitters at the same time, causing multipath issues.
John
Peoria
