Well... where to start.
I have a 25 foot mast ontop of a 20 foot house. I'm in Florida. Luckily, most directions are clear LOS.
I have 4 Antennas and feeds, A ST2, Radioshack Discone, VHF/UHF Airband, and ADSB Antenna from Flightaware. These 4 RG-6 (Quad Shield) go down to the base of my mast, where they have F-Type connectors. These are in weatherproof boxes, where they then go down to another set of F-Type grounding blocks. The total run is approximately 50 feet per feed. The system is grounded both at the roof, at the base of the mast, and also on the base of the house before the feeds run inside (via grounding blocks, bonded to a 8 foot copper rod and to my houses' neutral.)
1) The ST2 sounds good.
2) The Radioshack Discone sounds great!
3) The VHF/UHF Airband antenna is non-existent. When I connect the antenna, I can't even pick up the local NOAA weather station.
4) The ADSB Antenna is fair-poor, but it should be superb based on placement.
I guess my question is, I don't claim to know everything, but should I change all connections to N-Type or something else?
If so, what lightning suppression is recommended?
