I've checked the owner's manual & haven't found the answer to this.
I was travelling the other day & using a Favorites List that I had set up for that destination and the route taken. One of the systems I scan is the statewide P25 system. I assigned it a SysQK, and also assigned DQK's within the system. (For departments I use DQK's 00-79; for the sites, I use DQK's 80-99.) So as I moved from one county to the next, I wanted to turn off the sites in the county behind me. There are 7 sites covering that county, and I assigned all of them to DQK 80. So.......When I entered ".00.80 E", the scanner told me that DQK 80 was now ON. So I entered it again: ".00.80 E", and the scanner told me again that DQK was now ON. WHAT??? So I entered the same thing a third time, and a fourth time, and I kept getting the message that DQK 80 was now on. It did the same thing when I tried to turn off DQK 81 & 82, which had 3 sites and 2 sites, respectively, assigned to them. It just kept saying that they were now on. I checked in Sentinel when I got home to make sure that I had them enabled to begin with in the Department/Site Quick Key tab; so what I entered the first time SHOULD have turned them OFF, then when I entered it the second time it should have turned them ON......Right?
Obviously I am missing something, but for the life of me cannot figure out what it is.
