Wouxun KG-UV8D
CPerk
King William, Virginia
Was wondering can anyone instruct me how to get my comm port to download? I have downloaded the CHRIP program but my cable to program will not give me a com port number and Prolific will NOT install it showing the small triangle and Im beyond frustrated tried installing on Window's XP, Windows 10 and windows 7 NOT SURE, has be something Im doing wrong, I hope I can get this to work.. or at the most what to do now im beyond lost or
Can I get steps how to program BY hand how to program a frequency and the Alpha tags
greatly needed help badly
CPerk
Finally worked, sadly had to restart computer and software program
Now question is, on this radio , is there a such thing as like when I am at work and I use my work frequencies such as 461.xxxx when you key up is there any option to here the feedback like when you key mic up makes not like a static noise its like sound you know ur on a repeater system, right now i dont hear any feed back it like a simplex just keys up but my work radio i hear feedback ,since my work we key up radio when we do certain alarms so the crew knows it us not anyone else.
teufler
ST PETERS, MISSOURI
king willam cty
If its a work repeater, 461xxx, you need an off set, which should be 5.000 + off set. Sounds like you are keying the outpot, which in your work area, most you could hear. and talk too.,Your work probably uses a pl tone or dcs code, and maybe the other radios are full ctcss, meaning you have to have the code enter to access the repeater and the mobiles need the code entered to receive . Who ever handles the radios, should be able to give you all the particulars. If not, best not talk, but you have a good scanner to monitor with. I don't know what you do at the company but some companies are touchy about talking on "their" frequency. Would not want you to get in trouble. Perhaps just listening you acan stay one step ahead of the bosses, as you will know what they want before they get there. They will think you are clairvoyant. On Congrats on getting the Wouxan working. Wouxan recommended to use ONLY the uv8d software , not Chirp, and the Wouxan software has a few more options that Chirp doesn't handle. All the Chinese radios I have, Wouxan was the hardest to get functioning.
  • king william cty.pdf
