Hello,
I am having problems reliably streaming my BCD536HP audio via WiFi on my local home network. The audio stops streaming after a while. Sometimes it works for a couple hours. Other times it will stop after just 30 minutes. I have the same problem when using VLC or the "BCD536HP Audio Player" app on my Win7 64-bit Pro laptop.
When the audio streaming stops it cannot be restarted. The only thing that works is to power cycle the scanner then restart the audio stream. Also, when the audio streaming stops, the Uniden Remote Control app also stops updating and cannot reconnect. I am able to ping the scanner when when the issue happens so know there is some level of connectivity.
Are other folks having issues like this with extended periods of audio streaming on their local WiFi network?
The Uniden Remote Control app can run for days without hanging up. The problem only seems to happen when streaming audio.
