- Joined
- Dec 21, 2013
- Messages
- 135
I was informed that one of my feeds was not broadcasting. My system , not the feed one, has corrupted and I have spent the past 3 days fixing and installing new software, etc.
Today I have been trying to figure out what is going on. I am running RadioFeed and have so from almost the beginning. Everything shows it is working to the feed system.
I even took out the external speaker to see if I could hear the direct feed. I was able to from 2 different scanners.
I then thought that maybe that one of the audio cards had gone bad. The one in question is a USB card. I tried 2 different ones and still have the same issue. I also decided to try the main audio card and it made no difference.
I have run out of Ideas. I turned off the specific scanner for the feed and when it came back on, it tells me there is nothing to scan. Then I thought maybe everything got wiped. Everything is still there. So now I am thinking maybe something in the scanner has crapped out.
After several checks, it is in a ' blinking hold ' pattern scanning the ID's. I am unable to get it out of the hold. When I try, It goes into a search freq pattern. Still with the ' blinking hold ' at the top.
Nothing that so far I have been able to figure out has worked.
Any one have any ideas?
The scanner is a Uniden 996t.
