Thanks, I reprogrammed the scanner. I've gotten a few hits already, but so far most everything's been encrypted. I'll check the log in a few days and see what I'm getting and lock out the encrypted ones.
B should cover the Valley pretty well. I suspect if you can get C and not B you probably have some programming wrong. Don't forget they rebanded it to 700 MHz so you have to tell your scanner that.
