Mumblix_Grumph
- Joined
- Jan 27, 2015
- Messages
- 2
I've been hearing a computer-voiced dispatcher on FireComm. Have they fired the human dispatchers?
Been hearing the testing on A-5 from TFD; sounds awesome and 10x better than some of the human dispatchers, at least one of whom has such a thick "urban accent" he's nearly unintelligible.Tacoma Fire will also transition over to this system
We have been completing this project in 3 phases:
1) We turned on the 700 MHz Charlie 1 feed to test and it is now live.
2) We turned on the 800 MHz Bravo 3 feed to test and then moved it to Bravo 1 and live.
3) We will turn on the VHF feed over the next 10 days. This will have the 2-tone and DTMF paging built into it. Unfortunately we can't "test" it, so the test will be live and will cycle on and off as needed until it is working correctly.
As said above, it's for the initial dispatch only. We still have the same number of dispatchers. It's a balance between workload and available manpower. Having a computer system handle the initial dispatch gets the information out quicker, as the system can "queue" multiple calls at once, and while it is waiting for available radio air time, the dispatch as already been sent to MDC's and pagers/phones. Also, there are a few stations that have equipment that also will get be alerted in less than a couple seconds regardless of radio time.
This allows for the dispatcher that used to sit and pull up each call and select tones and read the information to work a fireground channel and not have to push their work to their partners while toning calls.
We don't have Locution, we have US Digital. While they can sound the same, the system is vastly different from Locution.
Tacoma Fire will also transition over to this system soon.
Thanks for everyone's interest!
Thanks for keeping us updatedThe last time I saw their talkgroups, they have them patched with the old analog system. I am assuming they must have taken the patches down and are completely on digital now. I am not sure if the digital system acts the same as the old analog system where the talkgroup ID changes when there is a patch. I'll see what I can find out.
I get Eatonville dispatch and car to car on 158.8275 DCS 243. If that helps any.
