c:\fmp -h >FMP-Help.txt
c:\notepad FMP-Help.txt
File/Print
Thanks exactly what I was trying to get
Usage:
FMP [options] Normal operation
FMP -h Show help
Options:
-i<num> RTL SDR device number (1-255) [-i1]
-o<num> Output audio device (1-255) [-o1]
-o<port> Output audio TCP port (256-65535)
-P<num> PPM value (-999.9-999.9) [-P0.0]
-g<num> RF gain (dB) [max]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial filter bandwidth (4, 7, 9.5, 12.5) [-b7]
-z<num> Show zoomed spectrum (0-1) [-z1]
-e<num> Enable/disable economy mode (0-1) [-e1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rv Role is trunk voice channel monitor
Active keys:
0-9 . Enter set frequency
[/] select step size
/ step frequency
Ctrl / step frequency by 250 Hz
M toggle spectrum memory overlay
X reset spectrum memory
Z toggle spectrum zoom overlay
I select injection mode
B select bandpass filter
E toggle economy mode
F select noise filter
/ adjust volume level
spacebar toggle muting
g/G adjust RF gain
c/C adjust frequency correction
R toggle raw I/Q and FM demod recording
S start scanner mode or exit hold mode
V start trunk voice following mode
? list active keys
Esc exit scanner mode or exit program
