Keep in mind you'll have to put the location and range data in if you create the site manually.
Creating it manually is what I'd do, but I admit that method might not be for everyone.
Here's step-by-step instructions from the information available:
- Edit your favorites list (star-with-pencil, or Ctrl+2); select the appropriate system, and click to the "Sites" tab.
- Click the green cross (oversized plus sign) to add a site. It'll add to the bottom of the list. You can type in the desired name, set avoid, modulation, atten, quick key, P25 wait, P25 threshold mode and level on this screen.
- On the left pane, find the new site you just created (will be at the bottom of that system), and click on it. The right pane will change to the empty site with headers "Frequencies", "Options", "Band Plan", and "Location".
- Select "Location" from the right pane.
- In the RRDB, on the appropriate system's page, click on the site name for the site you're adding. (Example: If it is indeed
this system, click on either "Cleveland Simul", "Walton Hills", "Chagrin Falls", or "Hunting Valley"). You will get the site details page.
- In Sentinel in the favorite list editor in the Location field, put in the lat/long/range as shown on the site details page. For example if adding the Walton Hills site, key in 41.37892 for the latitude, -81.57867 for the longitude, and 5 for the range.
- Click back to the "Frequencies" tab in Sentinel and press the green cross to add a cell. You probably won't be able to copy and paste frequency data from RR because it lists them in 1-3 rows of up to 7 columns apiece, instead of listing each frequency one to a row. But you can type it in. Keep pressing the green cross to add as many cells as you need. LCN order and LCN value has no meaning in P25 systems so you don't need to worry about that. If you're 100% sure that the control channels are listed properly in RR, you don't need to put in any of the channels listed on RR in black text; just the red (and possibly blue) ones. Otherwise, I usually put in all freqs, just in case the control channel rotates onto a freq that is otherwise thought to be a voice channel.
- The "Options" page lists all the stuff you had access to when you first created the site (on the grid view earlier on in this list). You can adjust it here if you want instead of on the grid.
- Don't forget to save when you exit the favorites list editor, and then upload the modified favorites list to your scanner.
Hope this helps!
