What you might want to do is access the menu for the P25 system SITE that you are receiving, either through the software or the scanner menu. When you select the specific site that is giving you the issue, you will want to change the P25 threshold mode to "Manual" and then adjust the threshold number. Start out at 8, then work your way down. Generally the lower numbers give you a lower threshold, so it may actually start to allow the entire conversation to pass squelch. This is different from the actual squelch setting in that it really has little to do with reception, unlike the squelch setting.
