You said, "They can't hear me". That would entice us to believe that you transmitted on that frequency.
468.xxx MHZ is not an Amateur frequency. That's smack in the middle of public service and business. I'd be real careful, if I were you.
This is just another reason why I think those BaoJunk radios should be banned. People buy them for 14 dollars at Amazon, with ZERO understanding of radio spectrum, and start randomly transmitting heaven knows where.
To answer your question, if the frequency has 4 digits after the decimal, it's a narrow-band frequency. If your radio is not narrow-banded, you'll never tune it in.
It's not "trying to decode something". It's just off frequency by 2.5 MHZ. You should probably try to get a basic understanding of radio before you start firing modulated signals into the ionosphere.
Without at least 1 of numerous possible licenses, you are allowed to transmit ONLY on the following frequencies:
40 CB Channels (around 27 MHZ)
5 MURS Channels (around 151.xxx and 154.xxx MHZ)
7 or 14 FRS Channels (around 467.xxx MHZ)
2 to 5 Marine Band Channels (around 156.xx MHZ, under VERY specific rules)
All of these will require you to know what exact frequencies, allowable power output, antenna limitations, rules for transmitting, etc., etc.
Your BaoFang is not approved for ANY of these, by the way.
Delta
Delta,
1. Thanks for answering my question!
2. I hang out in a few forums, here and there, so I knew that it was just a matter of time, until someone was "pointing" the finger at me, focusing more on what I am doing "wrong", than actually trying to answer the question, ha ha. Well, you did both! Its all good thought.
3. I can see where you are coming from. To 99% you can tell by the question that something isn't "right". Well, in my case, I thing there is nothing "wrong" with what I am doing. Let me explain. (in no particular order...).
I live in a Hotel. Obviously they are using a lot of radio communications to communicate. I bought some Baofeng radios to take with me on vacation AND because I would like to get my HAM license sooner or later. I guarantee you that where I went, nobody cares about my radios. Actually, there was no one around for hundreds of miles...
Anyhow. Since I got to know everyone that works here very well, we chit chat all the time. One day someone dropped his radio and got all freaked out, thinking it broke. (I believe the radio he was using is in the $800 dollar range...). The radio was OK. I then simply asked why they would spend this much money on a radio and not just buy something "cheap", like my Baofeng radios? The reply was that they doubt they would work as well as the "expensive" ones. So we figured to give it a try.
Here is the part where I could be wrong, but I doubt it:
They "bought" a certain frequency. One that is obviously different, than the ones used by all the other Hotels nearby. I believe that their "license" is in regards to their frequency, and not their radios. In other words, as long as they use THAT frequency, they can use whatever radio they want. Please correct me if I am wrong.
Back to the test... So if I stand there with them, tuning in to 468.512 on my Baofeng radio and press the PPT button, and say, "Hello, Hello", I seriously see nothing wrong with that. Or even illegal. They have a license to use THAT frequency and they are giving me permission to "use" it... That is how I see it, not saying that this is how it is! So please correct me if I am wrong.
Anyway, I learned a lot from your post. I appreciate you pointing out the frequencies I am allowed to use without a license (please tell me that I got that part right, ha ha).
A few more question you might not mind answering:
If I can tune in my Baofeng to one of the frequencies you have listed above, why would my radio not be approved for ANY of those?
Is it illegal to own my Radio. I think not.
I believe only transmitting is illegal without a proper license, but not listening, correct?!
That should be it.
thanks,
Kmd
EDIT: I just looked at the MURS wiki and I can see one thing that would not allow me to use my radio, which is that it has to be limited to 2 watts. But what if I limit my power to 1 watt? Could I then use it on the MURS channels?
