So I installed my home patrol scanner in the car , since it's a smart scanner I doesn't work unless I use a rectifier to bring the 12v down to 9v for power, now that there's a rectifier I'm getting static interference on the scanner and my ham radio...
What's the easiest way for me to get rid of the interference?
Thanks in advance
I believe what your trying to describe is an inverter power supply built into the plug that goes into the DC connector on the dash of a vehicle. The oscillator circuit in the plug is what is generating the noise. Most companies that make these cheap inverters, don't care about any radiated noise they may make. Very few times does a consumer call them on the carpet for the generated RF noise they may make.
One solution is to get some 500 MA or 1 amp. diodes and put 7 of them in series. This will drop the voltage from the 13.5 nominal volts in a vehicle to the 9 volts you are looking for. Each diode should cause a 0.6 volt drop.
Wire them with the cathode to anode and solder the connections. Put the cathode to the scanner and the anode end toward the vehicle source. Leave some wire between the diodes so they can be folded back on each other. Find some soft shrink tubing and slip is over all the diodes. Take the shrink tubing and cover the diodes, but don't pit the heat to it yet. Fold over 3 of them at a time. Then once they are folded back and forth, heat the shrink tubing just enough to get it to start to shrink. Then use another length of a larger size and sleeve the whole thing, including the wiring between the vehicle plug and the scanner cable connections.
Your noise should be gone and the scanner happy with the voltage it is getting.
