APX help
nick223
Ottawa Illinois
i am programming a apx 4k can someone tell me where to change the primary mdc. I see it under the conventional config tab as 1 and go into the cnv sys but dont see the primary id i do see the secondary id...
riveter
MD
Should be literally right above that on the CPS page. Should go:
Conventional System Name
System Type
System Group Number
MDC Primary ID
Secondary ID
Variable ID
nick223
Ottawa Illinois
System Type
System Group Number
MDC Primary ID
Secondary ID
Variable ID
That's what I was thinking..
car5le
Northwestern Montana
Assuming you have MDC enabled for the 4000 in your Conventional Personalities, you will be able to update one or all of the MDC's when you go Clone the radio. Go to Device > Clone Radio > Click on Read Radio or Read MDC, the lower part of that page will come up with the MDC information. That is where you update then write the new MDC back to the radio.
