I had a lot of hum in the background of my feed so I ordered a different usb sound card, the one in the wiki article to see if that would help. swapped it out and for some reason I'm able to hear what sounds like some type of mexican radio station in the background but at a low volume. Have you ever heard of this? Any idea what could be causing this? This is the soundcard I switched to: http://amzn.com/B000N35A0Y
I just turned off my scanner but left the audio cable hooked up to my scanner and usb sound card, and the music is still there? If I unplug the audio cable from the scanner with it off, the music goes away, then plug the audio cable back into the scanner with scanner still off and the music is back.
Do you want to listen to my feed to see if you hear it? Sherwood Police and Fire
I also tried a shielded audio cable from radio shack and the music is still there?
