anthonymodrow
Hey guys im learning how to use trunk88 any body familar with it i have a few questions
I've used it once or twice. What are your questions?Hey guys im learning how to use trunk88 any body familar with it i have a few questions
I guess what I should ask is can it be used as a tuner? I have a whole vast amount of tinkering programs that I been playing with but still trying to get p 25 running right.You create a folder for the program, dump all the files in, run the program and feed it a 3600 bps control channel signal.
What specific problems are you having?
I'm not sure p25 for sure apco p25 that I know ofWhat system are you trying to monitor? Trunk88 does 3600 bps CC only. If you are trying to use it on a 9600 bps P25 system, it will not work.
chris
Hey thanks for helping me out. Ya unfortuantly it is. Guess I go back to unitrunker bummer lolIs there analog talkgroups on the system? If so, it's a 3600 bps system. If it's 100% digital chances are it's a 9600 bps system.
Can it be used as a tuner? As in can it receive audio from a dongle? If so, then yes it can... it should detect the dongle when it starts up and ask you what frequency you want to park it on. Otherwise you need a discriminator or headphone jack audio input.
