Can some one tell me where I can the info on the RS106 to set up and use the win500.
node1 Member Premium Subscriber Joined Jul 20, 2010 Messages 53 Location richmond indiana Nov 21, 2015 #1 Can some one tell me where I can the info on the RS106 to set up and use the win500.
KT4HX Member Premium Subscriber Joined Dec 19, 2002 Messages 697 Location Spotsylvania County, Va Nov 21, 2015 #2 Here is some reference material for you to read in order to get familiar with WIN500. It works with several scanners, of which the Pro-106 is one. That should give you a basic understanding of what you are working with. WIN500 - UtahRadio Getting Started with Win500 - The RadioReference Wiki http://wiki.radioreference.com/index.php/GRE/RS_Object_Oriented_Scanners_FAQ Object Oriented Scanner Software - The RadioReference Wiki
gmclam Member Premium Subscriber Joined Sep 15, 2006 Messages 6,341 Location Fair Oaks, CA Nov 21, 2015 #3 WIN500 node1 said: Can some one tell me where I can the info on the RS106 to set up and use the win500. Click to expand... Once you've plugged in the USB cable, I think WIN500 will find it. If not, go to Device Manager to see what COM port is assigned.
node1 Member Premium Subscriber Joined Jul 20, 2010 Messages 53 Location richmond indiana Nov 21, 2015 #4 Thank you that gives me some place to look.
