Linked Capacity + Systems With > 8 Channels Understanding Thread Plus Raw Recordings
Hi All
This threads directed to the developers of DSDPlus, WinDSD, and others to implement updates to their program to enable the following of linked capacity plus systems with over 8 channels. Per Eric C., systems over 8 channels are not supported by the DSD programs because there were none at the time to test.
I recorded 7 raw audio files of a local system. Each file is from a different site/channel. See links below:
Site 6 Channel 9 - 10 (Voice traffic)
https://www.dropbox.com/s/7gfoj32uvqh6ggf/DSDPlus-Raw-Input_2015-11-23@210119.wav?dl=0
Site 5 Channel 9 - 10 (Voice traffic)
https://www.dropbox.com/s/p1cbo6oae2l1trd/DSDPlus-Raw-Input_2015-11-23@210404.wav?dl=0
Site 7 Channel 13 - 14 (Voice traffic)
https://www.dropbox.com/s/eqsfrc1crka5da3/DSDPlus-Raw-Input_2015-11-23@210539.wav?dl=0
Site 1 Unknown Chanel > 8 (Voice traffic)
https://www.dropbox.com/s/p61x40ne9h9vjxj/DSDPlus-Raw-Input_2015-11-23@211834.wav?dl=0
Site 1 Unknown Channel > 8 (no voice but several grants)
https://www.dropbox.com/s/r6x52i4w0eu0ycd/DSDPlus-Raw-Input_2015-11-23@211941.wav?dl=0
https://www.dropbox.com/s/jhm6vnxjiwzmldl/DSDPlus-Raw-Input_2015-11-23@212714.wav?dl=0
https://www.dropbox.com/s/ywphdbnqu5z0p5t/DSDPlus-Raw-Input_2015-11-23@212913.wav?dl=0
The last 3 had lots of grants but no voice. It would be great if someone would let me know the channel numbers for the 4 site 1 recordings if possible.
In addition I believe at least 1 Private call was recorded above.
Hopefully the developers would be able to figure out how to support systems with over 8 channels.
thanks
Joe
Originally Posted by EricCottrell View Post
Hello,
It is a problem with DSDPlus, but likely would also occur with DSD. When Cap+ was being figured out, the biggest system monitored was eight channels (4 repeaters). There is a status message that normally shows activity for channels 1 to 8, and 6 talkgroups. It is known that fields change to show activity for channels 9 to 16, but exact details were difficult to get. Most Cap+ systems are 8 channels or less.
It would be very helpful if you could do a raw recording with DSDPlus when this event occurs, so the developers could see what changes in the messages occur. A recording during peak activity would likely be the best time.
What system is this?
73 Eric
Hi All
thanks
Joe
Hello,
73 Eric
