BCD436HP/BCD536HP: New firmware update
Herodog
Aylett va
I would pay a $100.00 if they can come out with tbo fix and put the wild card feature on uniden scanners like wishlers and gre and make 436 so it would charge while listen to the scanner
Herodog
Aylett va
OK didn't know that I had gre all my life first uniden I ever owned thanks I try to find that. And that will show talk groups?
mitbr
Tampa Bay Florida
Its easy select the trunked system you want to id search on hit function then e on the keyboard it will not work in the data base only in favorites list.
Tim
Herodog
Aylett va
Well thanks guys working get I found I'd search as far as $100 I like to have the scanner charge as you use it and dmr /tbo I never thought uniden had that feature sorry for the post should have looked closer but thanks
Voyager
Yes, it will. In the settings for that System, set ID SEARCH to ON.
Menu button
Manage Favorites
(select FL)
REVIEW/EDIT SYSTEM
(select system)
EDIT SYS OPTION
ID SEARCH
ON
And you're very welcome.
