I would agree, there are many amplifier models and the instructions in the manual or looking at the schematics should address this.That would depend on the design of your amplifier. If it has a pass-through when off as part of its design, you should be OK transmitting on UHF with the amp powered off. Less likely is your amp having the ability to pass UHF signals through while powered on. With the popularity of dual-band radios you might get lucky, but I wouldn't count on that. Your answer is something you should seek from the amp's support line since they would be the ones that know (or can ask their engineers for) the answer. Posting the amp's make and model here may give you a better chance of getting a more accurate answer on these forums since some ham just might have the same setup and tried it out.
My mobile is putting a 50 watt on 2 meters would an amplifier that made it a 100 make a big difference worth spending the money? My antenna says it'll handle 150 watts
Sent from my SM-N915P using Tapatalk
As posted above, not much practical difference. IMO, it would only be a benefit if you had repeaters just a little too far for full quieting, since it would probably make a scratchy input signal clean up a little.My mobile is putting a 50 watt on 2 meters would an amplifier that made it a 100 make a big difference worth spending the money? My antenna says it'll handle 150 watts
Get yourself a small VHF beam instead! I have one made by ELK, and it can be used as a portable beam or mounted on a rooftop. It really increases your effective radiated power, and helps a great deal with receiving as well. For not much over $100 bucks, it is well worth the money!My mobile is putting a 50 watt on 2 meters would an amplifier that made it a 100 make a big difference worth spending the money? My antenna says it'll handle 150 watts
