chrispitude
Hi folks! I have two Liftmaster LM3800 garage door openers, which are jackshaft openers that get mounted on a front torsion spring:
LiftMaster LM3800 - Album on Imgur
The range of the built-in "antenna" is terrible - there are MANY complaints about its range online. If you look at the pictures, you'll see one long purple wire hanging straight(ish) down, and one short wire bent off to the side at a right angle(ish).
So I ordered two Liftmaster antenna extension kits. The kit contents are shown in the second picture. It's an L bracket, an antenna, and a coax cable. However, the installation instructions say to cut off one end of the coax, unwind some outer braid, attach the braid to a ground source inside the opener, and solder the end of the inside coax conductor to the end of the long purple wire.
Quite frankly, this sounds like a dreadfully horrible way to install it.
What I'd like to is to drill a hole and mount a male F jack somewhere on the opener. However, I'm not sure of the best electrical method for doing this. (I'm a digital electronics E.E. and all my analog knowledge drained out of my brain 20 years ago!)
I see 75/300 baluns that have two two screw terminals. Is that the proper way? Which is appropriate, a 1:1 balun or 4:1 balun? Does the right answer depend on how the board-level impedance was designed? What's the purpose of the short purple wire? Is it possibly the same as ground? (I can't tell without removing the board, which isn't trivial.)
I included a picture of the antenna length. The openers operate at 315MHz. Is this a suboptimal antenna design? If I can do better, I'm all for throwing some/all of this kit away and doing it right.
Another question - I have two openers and need two antenna extensions. Are there any restrictions on how the two remote antennas are mounted? Do I need to maintain any minimum separation distance, etc.?
All advice is appreciated. Thanks everyone!
