I've been using UT with both my old tapped Pro2006 (control) and RTL-SDR stick (voice) and it's generally worked okay. However while trying to tune the audio I noticed the audio output through VAC is very loud and clipped which is making it difficult for DSD+ to decode without errors. This is especially true with weaker signals. There doesn't seem to be any adjustment for UT to adjust the audio gain, and controlling through windows, while the volume can be adjusted, the audio is still being clipped and does nothing to help with decoding. Using DSDTune really made no difference. The audio from SDR# is a lot cleaner and seems to decode with fewer errors, although it doesn't help much when decoding the area's trunking system.
Is there some type of setting that can help with this issue? Thanks!
