Just got this scanner. Worked fine for a few hours then it would stop on a analog freq while scanning and would scan each channel for about more 10 seconds. Does the same thing for a trunking P25 system also. Is there a setting I need to look at and change? I have turned off the delay for each channel as I thought that may be an issue also. So far no luck. Any help would be great! Thanks!
