Yes, they have went to a simulcast system. Depending on what model scanner you have and where you are located in relation to one of the sites you may or may not be able to pick the system up very well. Simulcast causes a lot of multipath problems in scanners.
I've been running pro96com for a day here is the information I have so far, maybe someone can update the database.
On a side note someone posted a list a while back of the freqs that they are licensed for and there are more than what is showing up right now. Not sure if they are for future expansion or other uses.
The talkgroups I have identified are named, the rest I'm not sure about although I think the ones toward the bottom are some type of patches. I did not that Crossville PD was patched in on the P25 system last night on one of the 9000 series talkgroups.
System ID : 00A
System Name :
WACN : 926E0
Tower Number (Decimal): 10-10
Tower Number (Hex) : T0A0A
Tower Description :
Control Capabilities : Data,Voice,Registration,Authentication
Flavor : Phase 1
Call Sign(s) :
Timestamp : Sat Dec 19 11:14:47 2015
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
01,453.00000,0.01250,5.00000,"Confirmed",0.01250,1
09,453.00000,0.01250,5.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-0567","cav",460.08750,"01-0567",465.08750,0,74
"01-0585","av",460.31250,"01-0585",465.31250,0,74
"01-0595","cav",460.43750,"01-0595",460.43750,1,4
"01-0609","cav",460.61250,"01-0609",465.61250,0,70
"02-2618","v",0.00000,"02-2618",0.00000,0,0
"09-1134","v",460.08750/0,"09-1134",465.08750/0,0,0
"09-1170","v",460.31250/0,"09-1170",465.31250/0,0,0
"09-1218","v",460.61250/0,"09-1218",460.61250/0,1,0
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
1,50,"T: 1010 DT: 12/19/15@8:03",1450533832,"12/19/2015 @ 08:03",1450533832,"12/19/2015 @ 08:03","#000000","#000000","N",0
101,50,"T: 1010 DT: 12/18/15@12:51",1450464679,"12/18/2015 @ 12:51",1450464679,"12/18/2015 @ 12:51","#000000","#000000","N",0
200,50,"EMS",1450545816,"12/19/2015 @ 11:23",1450462283,"12/18/2015 @ 12:11","#000000","#000000","N",268
201,50,"T: 1010 DT: 12/19/15@8:03",1450533789,"12/19/2015 @ 08:03",1450533789,"12/19/2015 @ 08:03","#000000","#000000","N",0
202,50,"T: 1010 DT: 12/19/15@8:03",1450533792,"12/19/2015 @ 08:03",1450533792,"12/19/2015 @ 08:03","#000000","#000000","N",0
205,50,"T: 1010 DT: 12/19/15@8:03",1450533798,"12/19/2015 @ 08:03",1450533798,"12/19/2015 @ 08:03","#000000","#000000","N",0
206,50,"T: 1010 DT: 12/19/15@8:03",1450533801,"12/19/2015 @ 08:03",1450533801,"12/19/2015 @ 08:03","#000000","#000000","N",0
400,50,"CC FIRE",1450533815,"12/19/2015 @ 08:03",1450462373,"12/18/2015 @ 12:12","#000000","#000000","N",86
401,50,"T: 1010 DT: 12/18/15@12:28",1450533809,"12/19/2015 @ 08:03",1450463337,"12/18/2015 @ 12:28","#000000","#000000","N",2
402,50,"T: 1010 DT: 12/18/15@12:29",1450471055,"12/18/2015 @ 14:37",1450463340,"12/18/2015 @ 12:29","#000000","#000000","N",1
403,50,"T: 1010 DT: 12/19/15@9:10",1450537809,"12/19/2015 @ 09:10",1450537809,"12/19/2015 @ 09:10","#000000","#000000","N",0
406,50,"T: 1010 DT: 12/18/15@12:29",1450463375,"12/18/2015 @ 12:29",1450463375,"12/18/2015 @ 12:29","#000000","#000000","N",0
600,50,"Sheriff",1450545753,"12/19/2015 @ 11:22",1450462207,"12/18/2015 @ 12:10","#000000","#000000","N",844
601,50,"SO ADMIN",1450470528,"12/18/2015 @ 14:28",1450463450,"12/18/2015 @ 12:30","#000000","#000000","N",3
800,50,"Rescue",1450467317,"12/18/2015 @ 13:35",1450463419,"12/18/2015 @ 12:30","#000000","#000000","N",0
801,50,"T: 1010 DT: 12/18/15@21:02",1450494157,"12/18/2015 @ 21:02",1450494157,"12/18/2015 @ 21:02","#000000","#000000","N",0
802,50,"T: 1010 DT: 12/19/15@9:07",1450537673,"12/19/2015 @ 09:07",1450537673,"12/19/2015 @ 09:07","#000000","#000000","N",0
803,50,"T: 1010 DT: 12/19/15@9:07",1450537678,"12/19/2015 @ 09:07",1450537678,"12/19/2015 @ 09:07","#000000","#000000","N",0
805,50,"T: 1010 DT: 12/19/15@9:09",1450537757,"12/19/2015 @ 09:09",1450537757,"12/19/2015 @ 09:09","#000000","#000000","N",0
1000,50,"T: 1010 DT: 12/18/15@12:30",1450463426,"12/18/2015 @ 12:30",1450463426,"12/18/2015 @ 12:30","#000000","#000000","N",0
1001,50,"T: 1010 DT: 12/19/15@8:44",1450536287,"12/19/2015 @ 08:44",1450536287,"12/19/2015 @ 08:44","#000000","#000000","N",0
1002,50,"T: 1010 DT: 12/19/15@8:44",1450536297,"12/19/2015 @ 08:44",1450536297,"12/19/2015 @ 08:44","#000000","#000000","N",0
1003,50,"T: 1010 DT: 12/18/15@12:29",1450463344,"12/18/2015 @ 12:29",1450463344,"12/18/2015 @ 12:29","#000000","#000000","N",0
1004,50,"T: 1010 DT: 12/18/15@22:16",1450498592,"12/18/2015 @ 22:16",1450498592,"12/18/2015 @ 22:16","#000000","#000000","N",0
1008,50,"T: 1010 DT: 12/19/15@8:45",1450536306,"12/19/2015 @ 08:45",1450536306,"12/19/2015 @ 08:45","#000000","#000000","N",0
1200,50,"T: 1010 DT: 12/18/15@18:43",1450485784,"12/18/2015 @ 18:43",1450485782,"12/18/2015 @ 18:43","#000000","#000000","N",1
1201,50,"T: 1010 DT: 12/18/15@13:58",1450468697,"12/18/2015 @ 13:58",1450468697,"12/18/2015 @ 13:58","#000000","#000000","N",0
1202,50,"T: 1010 DT: 12/18/15@12:29",1450463351,"12/18/2015 @ 12:29",1450463351,"12/18/2015 @ 12:29","#000000","#000000","N",0
1203,50,"T: 1010 DT: 12/18/15@12:20",1450462830,"12/18/2015 @ 12:20",1450462830,"12/18/2015 @ 12:20","#000000","#000000","N",0
5010,50,"T: 1010 DT: 12/19/15@11:23",1450545877,"12/19/2015 @ 11:24",1450545825,"12/19/2015 @ 11:23","#000000","#000000","N",3
5012,50,"T: 1010 DT: 12/19/15@11:24",1450545885,"12/19/2015 @ 11:24",1450545844,"12/19/2015 @ 11:24","#000000","#000000","N",2
9001,50,"T: 1010 DT: 12/18/15@13:48",1450468760,"12/18/2015 @ 13:59",1450468110,"12/18/2015 @ 13:48","#000000","#000000","N",20
9002,50,"T: 1010 DT: 12/18/15@13:56",1450468760,"12/18/2015 @ 13:59",1450468607,"12/18/2015 @ 13:56","#000000","#000000","N",3
9103,50,"T: 1010 DT: 12/18/15@13:56",1450468597,"12/18/2015 @ 13:56",1450468597,"12/18/2015 @ 13:56","#000000","#000000","N",0
36723,50,"T: 1010 DT: 12/18/15@12:12",1450462336,"12/18/2015 @ 12:12",1450462336,"12/18/2015 @ 12:12","#000000","#000000","N",1
65116,50,"T: 1010 DT: 12/19/15@8:30",1450535442,"12/19/2015 @ 08:30",1450535424,"12/19/2015 @ 08:30","#000000","#000000","N",2
65117,50,"T: 1010 DT: 12/19/15@9:09",1450537792,"12/19/2015 @ 09:09",1450537769,"12/19/2015 @ 09:09","#000000","#000000","N",2
