What radios can do analog site roaming (vote scan)?
kblazk
Which manufactures today have radios that will do ANALOG vote scan (of the sites) in the subscriber radios? Right now I can only find EF Johnson VP600/900 series portables that will do this and I have attached a screenshot of the programming software showing this option.
I see a lot of other manufactures have some sort of conventional site roaming with their digital formats, NXDN and Mototrbo but I am specifically looking for ANALOG site roaming at the subscriber level.
trumpetman
Charlotte, NC
I've seen vote scan on the Motorola ASTRO25 series, ASTRO series, & APX series (all of which is a flash option). I've only ever used it on P25 but I would double check to make sure it's compatible in analog mode.
I've seen it in my XPR7550 too but haven't researched it enough to see how well it works (I think it's for Tier 2 radios only....I don't recall seeing it in my 6550 codeplug).
Can't advise on the older EFJs, I don't have PCConfigure in front of me to check the options or scan list type.
Hope this helps.
kblazk
trumpetman,
Are you saying that a XPR-7550 will do ANALOG site roaming? I just looked at the CPS and all I could find was the attached screen and it says at the bottom that feature only works in digital mode.
kblazk
Trumpetman,
I think I found what your talking about. Check out the screenshot below. I would like to see someone that has used this in a production environment, looks very interesting!
freddaniel
Newport Beach, CA
Tait analog radios use to offer something call mobile voting, for use on ribbon-systems along highways where two channels would alternate and the radio would home on the best channel.
RFI-EMI-GUY
I think Motorola called theirs System Search and Lock. It requires the subscriber to periodically poll repeaters with a specific DCS code and listen for a cooresponding CTCSS tone. It wasrudimentary in that it did not build an RSSI table to vote from.
