Programming my Baofeng UV82 and windows 10 ?
jerry092975
Chester County, Pennsylvania
Why can't i program my Baofeng uv82 with Chirp on windows 10, Is there a way around the error, It worked ok with windows 7 then I installed windows 10 and all I get is errors even with the prolific driver.....HELP:confused:
bama9999
Gulf Coast
Not sure which cable you have, but I have the one that uses the FTDI driver. My UV-82HP wouldn't work with the stock Windows driver, so I had to download and install the latest FTDI driver, and then it worked fine. I am using Windows 10 as well.
jerry092975
Thank you Bama9999, You wouldn't happen to have that link would ya if so THX
DickH
If everything was working well with Windows 7, why would you install Windows 10? Don't you remember the old adage, "If it ain't broke, don't fix it"? :)
