ICOM F9011 Scan
adko701
Whitehall Wisconsin
Hello all
I am having issues with my F9011 radio scan speeds. It scans really slow, I'm only scanning about 6 channels. And this is on the conventional side.
12dbsinad
Under Scan, then Scan setting, what are the fast and slow scan timers set at?
Also, this should be moved to Icom land mobile as this is a P25 trunking radio.
adko701
Whitehall Wisconsin
F9011 Scan
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Actually all you did was repost in the correct forum.
I've merged your old thread with your new thread.
Next time, just use the Report Post icon and ask that a Moderator move your thread.
Thanks.
12dbsinad
When you say it scans slow, I take it you mean it takes a long time for the radio to open up while scanning correct? Also, priority scan or normal scan?
12dbsinad
It's hard to tell without seeing the entire codeplug. I do see you have mode dependent scan enabled. When you enter a conv channel it will default to scan list 1 for that channel. Make sure you don't have that set for channels you don't want to scan, because it will on scan list 1 unless you select disable on each channel. Timers look ok. I've got some of these in the field and they scan great.
