Is The Motorola MT2000 Narrowband?
sam55671
NJ
Hello,
I would like to know if the MT2000 with the model number H01KDH9AA7AN is narrowband compliant.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
sam55671
NJ
SteveC0625 The Model number is different on the one I have
N1GTL
CT
Hello,
If the 7th digit is a 9, it can be narrow banded so you should be able to with that model number.
SteveC0625
If it's an A model, that may require hardware changes at the pcb level.
I tossed all of my personal charts on NB compliance so I am relying in part on info from others here. But everything I read suggests that only the K, R, and S models are NB compliant.
In any case, none of the MT2000's will do the the splinter channels (2.5 Khz).
Nasby
Ohio
Depends on the Firmware. I have an MT2000 with the last Firmware Motorola released for it (v2.04) and it most certainly does the 2.5 splinter channels. Via a 1999 era DOS setup.
I'm pretty sure that all of the Jedi series units will do the 12.5 narrowband programming.
However, only the "D" series HT1000's and the JT's, MT's and MTS's with the proper firmware would do the 2.5 splinter channels.
