TK-760G-1
Res21cue
Res21cue
Trying to program a TK 760G-1 with KPG56D. I am using a USB cable and I can get as far as making the radio display - PC - so its recognizing that its plugged into a computer but it will not read. Just says to check connections. I have tried every option possible. Com port is correct.
Do I need a serial cable to program this radio? Ive never ever needed to use a serial for any radio I have done in the past.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
sounds like you may have the wrong software.. there are two that do the 760, KPG29 and KPG56D..
Res21cue
Res21cue
I was hoping I could use the windows version. KPG56D as I do not have anything lower than Windows 10 right now nor do I have a serial cable. Why would it go as far as to recognize that its hooked up by displaying - PC - ?
b-stukey1
Sounds like you have a bad connection with your cable. Could be on either end or a break in the wire. Kpg56d is the correct software for the tk760g model and a USB programming cable will work, don't need a serial cable unless trying to run in dos.
Sent from my XT1254 using Tapatalk
Res21cue
Res21cue
I thought about the cable being bad too but then I used it to successfully program 2 7160s and an NX-700 with the same computer so I know the cable is good. Any other ideas?
llu727
New Jersey
I suspect the problem is Windows 10 - especially if it is 64 bit.
That was written in the Win2K /XP era - you may need to downgrade.
llu727
New Jersey
Thats most likely the problem.. support for that radio was discontinued in 2013.. way before 64 bit systems were common, let alone Win 10!! It works quite well on XP, havent tried it on 7, 8 or 10.
